who went to glamis C.A. this weekend???
Old Oct 31, 2005 | 01:10 AM
cloudyfz's Avatar
Default who went to glamis C.A. this weekend???
wheto to glamis this weekend... was bad ***... the only thing i didnt like was all the ruts... i have a yfz 450 what can to do to soften up the suspension im 5" 11 and 135lbs... the bike is real bumby espesialy in the front end..
Old Oct 31, 2005 | 11:03 AM
Glamis700's Avatar
Lucky you, i was busy puttin a programmer on my Raptor.
There are a few things you can do. First and easiest thing to do is too lower the compression dampning on the shocks. That will make it compress faster and softer.You can adjust the rebound to make the suspension extend slower or faster.
At your weight, id say you need to back off the preload on the springs. This is done simply by loosening the threaded collar\rings on the shocks. If you go a significant amount, you may need to check the alignment and adjust the steering.
I would adjust one setting at a time, either keep a mental note or write it down as to what setting you were at, what setting it felt better, ect ect ect.
Jeff Roper
Feb 1, 2022 11:48 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
bvolks
Sep 13, 2015 12:57 PM
