wow, something def wrong with carbs..
Old Nov 2, 2005 | 05:51 PM
ZimRaptor's Avatar
Default wow, something def wrong with carbs..
ive come to the conclusion that almost every time now i cant get it started because its flooded...it takes forever to finally turn over...well anyways today i was in the bush riding with a buddy and all of a sudden it just sputtered and stalled...i put it into reserve hoping the tank was almost empty, no luck...then hes like "dude cant u smell that?" so then i start snooping around and then saw the 2 overflow tubes gushing out gas like mad...somethings definitely wrong with the carbs
anyone had similar problems or know whats wrong with them?
Old Nov 2, 2005 | 05:54 PM
caliraptor's Avatar
floats are getting stuck.
Old Nov 2, 2005 | 05:58 PM
ZimRaptor's Avatar
lemme guess....from a pileup of dirt?
Old Nov 2, 2005 | 10:53 PM
hondarulesinnc's Avatar
It could be from grit, or also one of my friends laid his motercycle over and then the float started getting stuck so if you have fliped it or something that could also be it.
Old Nov 3, 2005 | 12:16 AM
LivinInVegas's Avatar
If you haven't done any jetting in a while and this just happened. I would guess that the floats are stuck also. Maybe you should take that carb apart and clean it up good while you check the floats. Also a bottle of fuel injection cleaner in the gas tank won't hurt.
bmxatv10
Oct 14, 2022 06:23 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
cboler9
Sep 24, 2015 08:35 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
