Rear sprocket combo.
Old Nov 3, 2005 | 07:34 PM
PolishCowboyPL's Avatar
Default Rear sprocket combo.
Alright If I want to increase acceleration I have to increase the number of teeth on my rear sprocket correct? A 3 tooth increase is equivilant to 1 tooth up front. If I'm not wrong then a Raptor's stock rear is 40 teeth. I have a 12 tooth up front and if I wanted to go to a 43 tooth rear would I have to change the change? Or just have to adjust it?
MIke.
Old Nov 3, 2005 | 07:37 PM
warriorguy22's Avatar
2 teeth change in the rear is equal to one in the front, and you might have to change your chain... depends on how loose it is.
Old Nov 3, 2005 | 07:46 PM
Its a 2 tooth change up though right?
MIke.
Old Nov 3, 2005 | 08:09 PM
HappaRap's Avatar
Lazy Boy Rider!
1 tooth drop in front equals 2.75 on rear
Old Nov 3, 2005 | 09:39 PM
Air's Avatar
Air
Gear Ratio Chart
Old Nov 3, 2005 | 11:50 PM
When is the cut off for the stock chain with a 12T sprocket up front? How many teeth can I go up in the rear without changing is what I'm asking.
MIke.
Old Nov 4, 2005 | 01:50 AM
HappaRap's Avatar
Lazy Boy Rider!
13/40 = 12/42.75 You should be able to go up to 42T rear with a 12T front with a stock chain, of course depending on how stretched the chain is, but on the other hand, you should change the chain with the new sprockets anyway.
mywifesquad
8
Sep 21, 2015 08:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
