2004 400 - 89 miles and FIXED
Old Nov 5, 2005 | 09:52 PM
NovaSS's Avatar
Default 2004 400 - 89 miles and DEAD
Well Im not happy with my cat . Today it refused to start except for an attempt to idle with full choke. Everything points to a clogged main jet. I went to look at the fuel filter but the factory didnt install one, how cheap.
Should I pull down the carb or drag it to the shop and try to fight it out ( repair bill)??? Im affraid if I pull it down and find something realy stupid ( plastic / metal shavings from production) I would not stand a chance of getting it covered . I know the warranty is out but has anyone had any luck with stuff like this on a bike with such low miles?
Old Nov 5, 2005 | 10:38 PM
mrtool2u's Avatar
From what I have seen not too many wheelers/ bikes use filters. It should be filtered in the tank on the petcock.
Old Nov 5, 2005 | 11:42 PM
ethernut's Avatar
See if this helps...
http://www.arcticchat.com/forums/ind...howtopic=22968
EtherNut..
Old Nov 6, 2005 | 12:27 AM
Bear4570's Avatar
Is it new off the dealer's floor or used and been sitting in someones garage? With something with this few miles I would suspect bad gas, either wet or stale or both. May not be dirt at all. Need more info.
Old Nov 7, 2005 | 11:41 AM
NovaSS's Avatar
Default 2004 400 - 89 miles and FIXED
Well I pulled it out today( easiest carb to pull on any bike I ever played with) and yep it was dirt in a jet and the seat for the float.
Runs great, now time to jet it and slap a muffler on it.
Old Nov 7, 2005 | 08:46 PM
swampyjunior's Avatar
You can definitely find a lot of junk almost any of the gas sold at the pumps. I filter my fuel through a paper and ceramic filter via a hand pump prior to putting it in my machine to keep just such a problem from occuring. Especially when you are miles from the shop to repair it!
Glad to hear you got it fixed.
Swampy
Jmuddin284
Jan 19, 2026 07:16 AM
COFatboy
May 2, 2020 12:06 AM
greg74
Sep 10, 2019 03:03 PM
velcro7279
Aug 24, 2015 01:15 PM
Gtsordo
Jul 13, 2015 10:38 PM
