Kazuma 110 noise by shifter
Old Nov 7, 2005 | 04:00 PM
Hershman's Avatar
Default Kazuma 110 noise by shifter
Seems like a raspy noise coming from the foot shifter area and while changing gears. Any thoughts, suggestions, test a capable novice could check to find the problem. It will shift and it seems to run alright. Is it the gear box? Is there something to tighten in it?
Old Nov 8, 2005 | 11:19 AM
Hershman's Avatar
Update.... I think it is the clutch because when I apply pressure to the shifter I really hear the raspy noise. Anyone know? Can I access the clutch without removing the engine? Does anyone know how long the warranty is? I bought last January from Raceway. John, any feedback?
Old Nov 8, 2005 | 11:24 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I would call john and ask him. The closest thing I have to your quad is a honda minitrail. And it has a few noisy rattles from the clutch cover that have never caused any harm.
Old Nov 10, 2005 | 07:53 AM
teej6's Avatar
I also bought from John in January, but I think now that you are our of warranty, but I suggest calling John anyway. You can get the clutch assembly for the 100 falcon all in one piece. In other words, you do not have to disassemble the clutch to fix a part, it comes as one unit. Slide the old one out, slide the new one in.
Teej6
Old Jan 12, 2006 | 09:08 PM
lannie's Avatar
The noise is coming from the chain rubbing on the chain guard. take the side guard off and you will see the marks. Ride it with out the guard and the noise will go away.
Solution, cut out a small section in the bottom part of the guard where it is rubbing
David
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
