1999 honda 450 es shifting problem
Is it pulling the cable after you push the red button and pull the brake lever? If it is I would follow the reverse cable down to where it hooks up down by the engine/ tranny, maybe it got disconnected there. You can use your emergency manual shift lever, but your reverse cable still has to be working correctly. Its mainly used in case you have electric shift trouble.
toonces
Oct 16, 2019 12:11 PM
