1999 honda 450 es shifting problem
Old Nov 19, 2005 | 07:16 PM
BOSSLX's Avatar
Default 1999 honda 450 es shifting problem
I cannot get it to shift into reverse. Every other gear is fine. When trying to put it in reverse you can hear it clicking.
Thanks, Andy...
Old Nov 19, 2005 | 07:20 PM
BOSSLX's Avatar
And is there a way to manually put it in reverse?
Old Nov 19, 2005 | 07:42 PM
Farmking's Avatar
Is it pulling the cable after you push the red button and pull the brake lever? If it is I would follow the reverse cable down to where it hooks up down by the engine/ tranny, maybe it got disconnected there. You can use your emergency manual shift lever, but your reverse cable still has to be working correctly. Its mainly used in case you have electric shift trouble.
Old Nov 19, 2005 | 07:58 PM
BOSSLX's Avatar
Bingo, thank you!!!!
hugemoth
Jul 20, 2020 03:28 AM
toonces
Oct 16, 2019 12:11 PM
sara durrant
Jul 6, 2015 05:32 PM
mudmachine
Jul 29, 1999 11:25 PM
