Starter noise
Old Nov 20, 2005 | 12:35 AM
gillly's Avatar
Default Starter noise
Well I changed the belt today, changed the front hub oil with synthetic ATF and changed the engine oil and filter on my recently purchased 2000 Magnum 4X4. Thanks for all the help with the above. I was saying that my clutch cover felt loose but it is just the flex you guys descibed. It also seems to have a starter noise as if the starter doesn't disengage right away. Probably should take it off and lubricate it? Also, what else do I have left to do on it before winter? Should I change the rear end and transfer case oil? I think those are the only two things left to do......
Old Nov 20, 2005 | 02:07 PM
UTU's Avatar
UTU
Take the circlip off the end of starter drive clean & lubricate. U can stretch the spring a bit too to have more tension on the drive to help disengage. Did this on a 300 express worked fine.
akguy31
Aug 31, 2019 04:34 AM
flyin-lowe
Dec 1, 2017 03:18 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
firsttimerider
Sep 20, 2015 09:07 PM
