Twist throttle
Old Nov 22, 2005 | 05:02 PM
mjm540ii's Avatar
Default Twist throttle
I have a twist on my 400 ex, (i dont like it) and it is very veery stiff. how do i free this up? where can i find a cheap thumb throttle (i keep seeing them tor about $115, and i dont want to pay that much)?
thank you,
-mike
Old Nov 22, 2005 | 06:04 PM
mjm540ii's Avatar
could i free it up with some wd40?
Old Nov 22, 2005 | 06:07 PM
maddog56's Avatar
Make sure that the cable isnt bound up anywhere. There are cable lubes out there for cheap, try some. Motion pro or terrycable can probably make you a new cable for under 20 bucks. You should also check to see if the throttle tube is sticking on the handlebars.
Old Nov 22, 2005 | 06:16 PM
mjm540ii's Avatar
thanks, im goin home from school for thanksgiving break, ill tear it all apart and look at it
but does anyone know where i can pick up a cheap thumbthrottle(other than ebay)
Old Nov 22, 2005 | 06:53 PM
maddog56's Avatar
Not unless you have an atv salvage yard nearby or a swap meet. Dealers will charge obscene prices and aftermarket offerings are about the same price. Your only other option is hope someone on an internet forum sells one.
Old Nov 22, 2005 | 06:59 PM
Tator397's Avatar
Hey man, i've got a 99 with a thumb throttle on it. i'm wanting a twist throttle, how old is your and the brand. if interestred in trading?
Old Nov 22, 2005 | 10:53 PM
counterpunch's Avatar
I think alba has some nice thumb throttles.
Old Nov 22, 2005 | 11:13 PM
Hotrodder250ex's Avatar
www.rockymountainatv.com has them fo about 40 bucks, they list it as a motion pro twist throttle if that helps fo rwut you are lookin for.
Old Nov 23, 2005 | 01:02 PM
Gruzzy's Avatar
If you lube your cable, use a lube with teflon in it. When I was a bicycle mechanic that's what we used to lube bike cables. WD-40 is ok but will evaporate in the long run, while the teflon will keep on lubricating. You will need to remove the cable and allow the lube to run down into the housing to get full length lubrication.
Pehter
Oct 3, 2024 11:00 PM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
89Lt250r
Sep 7, 2015 07:53 PM
