TRANNY LUBE
Old Nov 22, 2005 | 06:27 PM
ftwflh's Avatar
Default TRANNY LUBE
I know that Polaris recomends AGL synthetic in the tranny(chaincase) but has anyone ever ran Polaris Premium Chaincase lube the non synthetic kind made from mineral oil?Need to know if it will hurt anything.I got a case of this stuff right.
Old Nov 22, 2005 | 08:13 PM
cornbread2's Avatar
Default TRANNY LUBE
The chain in your trans will last much longer with the Polaris synthetic and even longer with good synthetic motor oil such as Castrol Syntec.
I would not use the old stuff in anything.
Old Nov 22, 2005 | 09:42 PM
spyder6's Avatar
Default TRANNY LUBE
Ebay, your best friend for cleaning out the garage
Old Nov 23, 2005 | 12:01 AM
cornbread2's Avatar
Default TRANNY LUBE
You can sell anything on EBAY and for three times what it is worth.
Old Nov 23, 2005 | 07:12 AM
jimmypsp700's Avatar
Default TRANNY LUBE
check this thread it may be helpfull...
http://atvquadsquad.com/groupee/foru...7666003655/p/2
also copied from another...
You can use Amsoil Series 2000 Chaincase lube. It works GREAT as a substitute to the Polaris AGL fluid.
BB
-'00 Scrambler 500 4x4
http://www.lubes4u.com/Downloads/indust-xref_g1378.pdf
What you refer to as an automatic transmission is not. The Polaris has a belt driven "automatic" with a drive clutch (on the engine) and a driven clutch (on the input to the gearbox) and a belt in between. It is the gearbox that you are referring to. The gearbox does no gear shifting at all, other than when you switch from forward to reverse or to low. It is simply a transfer case of sorts that gets power from the clutch system to the rear wheels. It consists of a bunch of gears, sprockets and chains. The belt and 2 clutches do all the "gear shifting".
Do not use ATF in the gear box. There is nothing hydraulic about the gearbox. It requires a good quality synthetic gear lube. Personally, for the quantity required and the infrequent changes required, I use the synthetic offering from Polaris. Others here do use other products with no problems. I am sure someone will be kind enough to provide info on other products. My vote, us the Polaris stuff!
-DJ
bmark0610
Sep 7, 2015 09:42 PM
Logan Collins
Sep 5, 2015 08:03 PM
79hugger
Aug 30, 2015 02:21 PM
Haakon
Aug 24, 2015 01:54 PM
user493
Aug 13, 2015 12:54 PM
