tri-z clutch problem any help appreciated
Old Nov 25, 2005 | 05:25 AM
DaronCraig's Avatar
Default tri-z clutch problem any help appreciated
my tri-z is doing the following, when i am just putting around and then nail it the engine revs very high and then a couple of seconds later the gear catches up and goes. its like a delayed reaction from the push of the throttle to the wheels grabbing and going. can i adjust the clutch? what should i look for as far as wear on the parts? where could i get a new clutch assembly if needed? thanks!!
Old Nov 29, 2005 | 02:18 AM
okieRrider's Avatar
Sounds like the clutch fibers are worn and need to be replaced. Denni Kirk sells them..
Old Nov 29, 2005 | 02:30 AM
69HemiGTX's Avatar
US Army lifer
Okie is right. Your fiber plates are worn out. Just get some new ones, and you'll be back in business. If it were me though, I would replace both the fiber and steel plates due to the amount of use they might have seen over the years.
Mkp
Mar 28, 2020 03:50 AM
txkevin
Sep 21, 2015 02:02 PM
Land_shark1
Jul 10, 2015 12:53 AM
FourWheelOverTwo
May 31, 2015 07:26 PM
blaze_master
May 26, 2015 11:18 AM
