sportsman chirps at idel
Old Nov 26, 2005 | 07:11 PM
Jayblazer's Avatar
Default sportsman chirps at idel
what do you think it has always done it but i think it is getting worse. any ideas??
its not a constant noise just every now and then "chirp"
Old Nov 26, 2005 | 07:36 PM
SPORTSMAN70003's Avatar
Let the little bird out that will fix it lol.
Does it do it when its cold and hot? You might have a vaccum leak or somthing.
Old Nov 26, 2005 | 08:50 PM
Polaridoo's Avatar
Is the clutch OK? Is the engine aligned alright? I am thinking the clutches are not aligned.
Old Nov 26, 2005 | 11:01 PM
okiedude's Avatar
Mine does it also. My noise does come from the clucth area. It does it at slow speeds...seems to go away when my rpm's get going. Will it hurt anything to let it go un-fixed?
Old Nov 27, 2005 | 12:06 AM
Polaris500HO4x4's Avatar
actually what i think you are hearing is the clutch letting go of the belt... as the clutch slides open with decreasing rpms it will let go of the belt causing a small churp churp churp sound
Old Nov 27, 2005 | 12:55 AM
Jayblazer's Avatar
it does not make the sound above idel at least not that i can hear just while its sitting and running..
Old Nov 27, 2005 | 01:24 AM
IdahoVinnie's Avatar
I would say that the belt is out of adjustment, or the sides of the clutch may need to be cleaned and resurfaced (by lightly sanding).
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
