got the 3 wheeler runing. ?
1982 honda 200 3 wheeler runs perfect but if you wind it out and go into a gear it slips a little then catches. it sat for years not runing. what type of oil should you use i would like to change the oil.
I use Amsoil 10w40 high-performance motorcycle oil. Meets JASO MA for wet clutches. I would recommend that or the Honda GN4 oil. The Amsoil is synthetic though, a little better heat stability.
