leaking weep hole
Old Nov 27, 2005 | 06:56 PM
hotrodhann's Avatar
Default leaking weep hole
I have a 1999 polaris 500 sportsman that is leaking small amounts of prestone out the waterpump weep hole. what do you think this is and how long should it take to fix.
Old Nov 27, 2005 | 07:35 PM
GSXRPred's Avatar
replace your water pump.
Old Nov 27, 2005 | 08:04 PM
cornbread2's Avatar
Yes it is the water pump seal.
And no matter what your dealer or service manaul tells you you do NOT have to pull the engine or go through a lot of BS.
Old Nov 30, 2005 | 09:38 AM
Cutty's Avatar
I had a seeping weep hole once back in the 70's...penicillin cleared it right up though...
Old Nov 30, 2005 | 09:45 AM
Hoopie's Avatar
I just had the same thing happen to my scrambler 400. the dealer replaced the water pump. Cost me about $400.
Old Dec 29, 2005 | 06:40 PM
Spears's Avatar
Just replaced the Mechanical seal on my 00 500. It was leaking out the weep hole also.
Dealer wanted 70 dollars plus costs of part to replace it. It takes a special tool to get it out without having to crack the case open. I bought the tool from www.victorspecialtytools.com
I figured I may need it again. Costs me about 90 dollars with shipping.
I bought the seal from Bikebandit.com.
Spears
Old Dec 29, 2005 | 07:53 PM
luckycharms5's Avatar
I can tell you this just about everybody I talk to has some sort of problem with the weep hole leaking. Gotta love polaris machines. i own one and had 10 problems being a 2003 and only 120 hours and 500 miles and a ton of money sunk in. Yes mine leaks also but Iam letting it leak. When I say leak I mean drip hear and there only.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
