XL 50 (SUNL) idle and start problems
Old Nov 30, 2005 | 11:22 PM
Chummley's Avatar
Default XL 50 (SUNL) idle and start problems
I just received my XL 50 from Raceway and after assembly, John had walked me thru to get it started. Since then it run with the choke on and did an idle for about an hour. When I push the choke in it will die and if still choked it will idle good but when I give it some throttle it will sputter and throttle up but not smooth. any suggestions anyone?
Old Dec 2, 2005 | 01:49 AM
Chummley's Avatar
Update: I adjusted the fuel / air mixture screw, cleaned the bowl, and it now purrs like a kitten!!
Thank you John, Vince from Raceway..
P.S. I took off the plastic and checked all wiring and found a loose positive wire to the starter solenoid and a loose wire to the light.[img]i/expressions/face-icon-small-smile.gif[/img]
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
sticky123
Jun 14, 2015 07:36 AM
Steven Bandemer
Jun 9, 2015 08:50 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
