Modifying Stock Muffler
Old Dec 1, 2005 | 08:21 PM
Haden's Avatar
Default Modifying Stock Muffler
I have been reading that many people are modifying their sock mufflers by drilling out the baffles. I currently have a sportsman 500 non HO and would like to possibly modify the stock muffler, but I do not want to loose any low end torque. I currently have a K&N and 29.5 outlaws. Would drilling out the baffles in the muffler help or hurt my performance? If it would help my performance would someone please instruct me step by step to correctly perform the modification. I plan on welding on a 1 ¾ turn down once the muffler has been modified.
Old Dec 1, 2005 | 08:46 PM
ftwflh's Avatar
If you have the $$$$ for that big of tires then why dont you get a decent pipe?And how do you turn them without a clutch kit?
Old Dec 1, 2005 | 08:52 PM
Haden's Avatar
First, The tires were given to me new. Second, I have no problem turning the tires. To date, I have not been able to bog the machine, I I have been In some bad mud.
Old Dec 1, 2005 | 09:01 PM
cornbread2's Avatar
Leave it alone.
After you ruin your stock muffler your ATV will sound and run like a POS and then you will just have to go to your local dealer and buy a new mufler.
And it will not be cheap.
Old Dec 1, 2005 | 09:02 PM
ftwflh's Avatar
Check out Heelclicker for a clutch kit or call them and tell them what you got and they can get you hooked up.These 500HOs have a good exhaust system.The power is hidden in the Polaris clutching.But is you must mess with the pipe go with either a complete HPD or Aaen system with the clutching they recomend. But for best $$$ do check out Heelclicker.
Old Dec 2, 2005 | 02:39 AM
IdahoVinnie's Avatar
By removing the baffles, you are reducing the restriction of the exhaust system. That allows for greater air flow, resulting in a better top end. Thus, bottom end will suffer somewhat.
Pehter
Oct 3, 2024 11:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
dannytas
Sep 26, 2017 06:31 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Bigtwin700
Sep 9, 2015 09:32 AM
