warrior neutral.
Old Dec 3, 2005 | 06:16 PM
paintballbanshee's Avatar
Default warrior neutral.
hey people, i was riding my warrior and we all stopped and my neutral light wouldn't go on, all of my lights except for that wasn't working. then my quad wouldn't start while it was in neutral without the clutch. i brought it home after the ride and i saw a wire hanging were my left leg is, (in that area), it seems like it has to be the neutral light, i spent like half an hour looking at were it could go, it definitely comes out of the main harness near the battery and is heading towards the startor, i just cant find the male part of the plug. thank you i hope you can help me
Old Dec 3, 2005 | 06:35 PM
Daniel631's Avatar
The neutral switch is on the left side of the motor. Look near the shifter for a sensor looking thing with a male end on it.
Old Dec 3, 2005 | 08:32 PM
does it look like a hook? im really trying to find this thing so ok its on the left side down low?
Old Dec 3, 2005 | 09:17 PM
swampman's Avatar
its like a sensor and it is down low, I'm pretty sure a holds it on. the connector end of the wire should have a round eye. on the motor it should look like a stud sticking out where the connector end goes on. the rubber boot still might be covering it
Old Jan 5, 2006 | 07:22 PM
trialsrider172's Avatar
maybe ur bulbs is dead...if all else fails, check that
Old Jan 19, 2006 | 01:07 AM
extremeatvrider's Avatar
the sensor has single wire running to it look at oil filter cover should have wire ran next to back side of it follow the sensor if looking at quad from left side is right behide shift arm pull sensor out and clean it make sure the pin in it moves freely
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
