95 Xplorer 400 problems
Old Dec 5, 2005 | 03:54 PM
alwazmt's Avatar
Default 95 Xplorer 400 problems
Hi,
I've got a '95 Xplorer 400 that has developed an interesting the problem. When the shifter is moved from neutral to high or low, the neutral light stays on I cannot get the bike into 4 wheel drive. I had the same problems a few years back, but a new battery seemed to fix the problem. I figured it was a coincidence, so I did not pursure it any further. Any ways, the problem is back and I cannot get the switch to come out of neutral even with a battery charger connected. The neutral switch goes off when I go to reverse, so I have 4WD in reverse. Does anyone have any ideas for me?
Problem number two is a starter starting to go out on me. Where is the best place to get a good replacement starter?
Thanks,
Jim
Old Dec 5, 2005 | 05:42 PM
cornbread2's Avatar
On the 95 you should have a switch on your shifter. It could be bad.
I could be wrong and the switch could be on your trans. Either way the switch is your problem.
It has been a while since I worked on a 95.
Old Dec 5, 2005 | 06:06 PM
ftwflh's Avatar
Your switch IS in the shifter.The best thing to do is find a complete shifter.A new switch is expensive from Polaris.The best place to find a shifter and a starter is Ebay.
Old Dec 5, 2005 | 06:38 PM
UTU's Avatar
UTU
Link to ebay Polaris starters-----> http://cgi.ebay.com/ebaymotors/ws/eB...Pr4_PcY_BIN_IT
Old Dec 6, 2005 | 03:41 PM
XpLo400's Avatar
call your dealer and ask them for used shifter's...My dealer have a pile of switch and shifter in the shop
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
cornermike
Jul 8, 2015 11:44 PM
