ES not work in the cold?
Old Dec 5, 2005 | 05:45 PM
jonnyyellow's Avatar
Default ES not work in the cold?
Well, since we got some snow yesteryday, i went out to play with my 05 ranches es...
the es wasnt shifting out of neutral for a second.. up or down.. then i turned the key off and on.. it still didnt work.. then i turned it off and on and it finalyl worked..
waht happened?
will the es brake down in future cold rides?
Old Dec 5, 2005 | 06:39 PM
MOSD's Avatar
There are a lot of posts on the possible cause of thi sproblem. Start with the condition of your battery and go from there. The service manual will direct you through the triage.
Old Dec 5, 2005 | 09:15 PM
hondabuster's Avatar
If youre still running 10w 40, a switch to 10w 30 might make it shift easier.
How long has it been since the clutch was adjusted?
And i agree with starting on the battery first. If its in doubt, have it load tested.
Old Dec 5, 2005 | 09:48 PM
well.. i got the quad two months ago.. since riding it again today real quick.. the shifter didnt have problems..
maby oil?
when changing.. do i need to empty it all out?
Old Dec 6, 2005 | 01:07 AM
IdahoVinnie's Avatar
I had a similar problem on my olr 450ES. The problem turned out to be an occasional sticking shifter button on the handlebars.
Old Dec 6, 2005 | 02:53 PM
Torbinx's Avatar
never had anyproblems but sometimes they stick and just have to be flushed with water...other times you just have to turn it off and on. very very minor
hugemoth
Jul 20, 2020 03:28 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
