Spark Plugs
Old Dec 6, 2005 | 10:13 AM
roadkillkeene's Avatar
Default Spark Plugs
Anyone know of an online manual that would tell me exactly how to change out the spark plugs on a Artic Cat 500i?
Old Dec 6, 2005 | 12:05 PM
mudslinginfool's Avatar
Does it in the Mud!
Default Spark Plugs
NO ,BUT 1ST MAKE SURE THE ENGINE IS CLEAN. ASSUMING ITS THE SAME AS THE 2002 500I,ON THE LEFT SIDE OF THE BIKE RIGHT BEHIND THE UPPER RADIATOR HOSE IS A BLACK WIRE. THAT WIRE CONNECTS TO THE SPARK PLUG. PULL THE WIRE OFF (TWIST A LITTLE IF YOU NEED TO IT MAY BE HARD TO PULL). ONCE THATS OFF,USE YOUR PLUG SOCKET THAT COMES WITH THE BIKE AND TAKE THE PLUG OUT. MAKE SURE THE THE GAP IS CORRECT ON THE NEW ONE( MANUAL TELLS YOU WHAT THE GAP IS) AND PUT IT BACK IN. IT GOES IN AT A SLIGHT ANGLE. SNUG IT UP PUT THE WIRE BACK ON ALL THE WAY AND YOUR DONE. ANY OTHER PROBLEMS LET US KNOW.
Old Dec 6, 2005 | 01:50 PM
TORK's Avatar
Default Spark Plugs
One tip if you have access to air, there is a tiny hole just below the sparkplug in the side of the cylinder head. If you blow into this with air hose the sparkplug boot will pop right off plus you will clean around sparkplug at the same time.
Big bousse
Sep 26, 2015 10:42 AM
cornermike
Jul 30, 2015 06:37 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
