front diff help
Old Dec 8, 2005 | 10:52 PM
lovemud's Avatar
Default front diff help
Hi,
My 4x4 works in forward but not in reverse, the "slow" warning flashes on the pod so I know its not electrical. Am I looking at ripping apart the front diff??
-lovemud
Old Dec 8, 2005 | 11:06 PM
x_scrambler3's Avatar
ARE YOU PUSHING THE REVERSE OVERRIDE BUTTON IN AT THE SAME TIME THE AWD WILL ONLY WORK IN REVERSE WITH IT PUSHED IN
Old Dec 8, 2005 | 11:30 PM
lovemud's Avatar
As I said, The flashing "slow" message comes on the display, this would only happen if the unit was in 4x4 and the reverse overide button was pressed...... I know it's not electrical.
I let someone plow with it and the 4x4 been acting funny every since, at first it wouldn't dissengage now it doesn't work in reverse. IT's got the single unit in the middle, there's something to say about having the lockouts on the hubs - easier to replace.
Old Dec 9, 2005 | 05:49 PM
Andre's Avatar
Change the front gear case fluid with Polaris Premium Drive Hub Fluid. Check out the old fluid for contamination, water mostly, there will be a small amount of metal/alum shavings.
Hopefully that will get your AWD back in shape. Good luck.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
Sportsman850
Jul 31, 2015 04:25 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
