Secondary switch for winch?
Old Dec 10, 2005 | 11:44 PM
MJF4866's Avatar
Default Secondary switch for winch?
I installed the AC(Warn) winch the other day with the rocker switch right under the starter button. I was wondering if anyone has had a problem accidently activating the winch. Or if anyone has installed a secondary switch that deactivates the rocker switch until it is needed. I was thinking a switch wired between the two parts of the plugin connection that is right in front of the "steering column". Comments? Thank you.
Old Dec 11, 2005 | 12:31 AM
Bear4570's Avatar
Yeah, I've had the fat thumb syndrome a few times. A cut off switch is a good idea. I think rather than interrupt the power to the winch switch (even though I know right where it runs) I might install a DTDP switch near the solenoid assembly and cut off the switch input to that.
Old Dec 11, 2005 | 12:40 AM
MJF4866's Avatar
Thanks for the idea Bear. I was thinking that I could mount the switch in that inspection plate that goes around the steering so that if I wanted to take it out sometime, replace the inspection plate, hole gone.
Also the solenoid is mounted on the frame, just in front of the oil cooler, above the motor end of the winch which makes it a little hard to get to.
Old Dec 11, 2005 | 12:43 AM
MJF4866's Avatar
I was also thinking that I wouldn't have to cut any wires by just plugging into and out of whats already there.
Old Dec 11, 2005 | 01:58 PM
petroleumboy's Avatar
Why not just leave you winch in the free wheel position. Then if fat fingers accidentally hit the switch, the gears aren't engaged!
Old Dec 11, 2005 | 08:58 PM
MJF4866's Avatar
Petroleumboy, I hadn't really thought about that until this afternoon when my uncle also mentioned it. Thank you for your insight.
fordfaithful21
Dec 7, 2015 05:52 PM
toonces
Sep 5, 2015 01:14 PM
user493
Aug 13, 2015 12:54 PM
Bratman2
Jul 23, 2015 12:36 PM
cornermike
Jul 8, 2015 11:44 PM
