Rubicon angle sensor
Old Dec 19, 2005 | 02:24 AM
dwpalmer's Avatar
Default Rubicon angle sensor
How do u know when you angle sensor is bad? Is it when you test the ohms(resistance) and its not b/w 1.6 and 2.4 kohms. Getting code five on the display, dieelectric greased all connections ill be test the ohms tomarrow.
Old Dec 19, 2005 | 02:30 PM
BCNUCS's Avatar
You got it. I think that is the only way to test them. I have even seen some that tested OK and still were bad. Thank god its a cheap part. I suggest keeping one on hand at all times.JMO
Old Dec 20, 2005 | 12:55 AM
JRM's Avatar
JRM
my rubicon is a 2001 with over 1000 miles, never had this part fail.... should I be concerned? Is it driveable if one dies out on the trail? Where is it located? My rubicon has been 100% bulletproof
Old Dec 20, 2005 | 08:23 AM
dwpalmer's Avatar
9000 miles of hell and i dont know if this the prob. Yeah its still ridable but it doesnt seem to go past 3rd gear. It tested 1.4kohms which is just below the specs, I think alls i have to do is pull the sensor off (underneath the exhaust) and turn the reduction gear a little.
Old Dec 20, 2005 | 05:45 PM
mack63's Avatar
DW I will have to concur that the rubi has been through 9000 miles of hell. Good luck with finding the problem. Hopefully we can ride soon.
Old Dec 20, 2005 | 06:14 PM
dwpalmer's Avatar
Hey whats up mack, , no did find it im going to try reseting the comp tonight, its just been too cold to do anything out in that garage, if not ill have to find time to take it out to fischers.
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
60
Dec 14, 2019 06:13 PM
patrick.oc123
Sep 15, 2015 02:45 PM
