can i do front bearings?
Old Dec 22, 2005 | 03:27 PM
chirochris's Avatar
Default can i do front bearings?
i need front bearings in the 86 350x
should i get them somewhere special or it doesnt matter
can i do this myself or do i need a special tool..were can i find a how to on these bearings
Old Dec 22, 2005 | 04:17 PM
ThrashAndCrash's Avatar
They are very easy to do. You will need to get the new seals from a dealer, or online. For the bearings I suggest you take it all apart and get the bearing # and call NAPA, or Carquest because you can usually get them for very cheap, and they are great bearings! Let me give you a hint: DO NOT take the line loose for the front brake; they can be a real pain to bleed out the air sometimes.
Unbolt the brake caliper
take the front axle bolt out
Knock the bearings and seals out
Just keep everything in order and it is pretty much that easy
Old Dec 22, 2005 | 04:18 PM
HERE is a breakdown of the front wheel
Old Dec 22, 2005 | 09:08 PM
chirochris's Avatar
thanks so much, i will try it
ebay has front bearings and seals for 10$ ... what do you think
Old Dec 24, 2005 | 04:57 PM
VERY GOOD price!!!!!! pop the plastic seals out of the new bearings; pack them with grease, and pop the seals back in place........It will make the bearings last a crapload longer
Old Jan 1, 2006 | 05:54 AM
kart38's Avatar
Wheel bearings are easy. Let me give a some step by step help here. To pound them out find a good punch that will reach through the center of the hub to the opposite bearing. Make sure the punch has a good flat face that your putting against the inner race of the bearing. Tap it out evenly so it falls straight out. When you put them back in Make sure to put the spacer back in the center of the hub after you get the first bearing in. Also, make sure you tap them in straight. I use a hammer and a socket that is the same size as the outer race of the bearing (never tap on the inner race of a good/new bearing, or you will need to replace it). Grease the axle before you put it back in. You will thank yourself later when you need to take it back out again for any reason.
Jason
Ean
Dec 19, 2022 08:48 AM
Peter_
Jul 18, 2015 07:06 AM
JackTheKing
Jul 14, 2015 09:09 PM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
