Arctic Cat Z 5 Pro idle problem
Old Dec 23, 2005 | 09:51 PM
fastback39's Avatar
Default Arctic Cat Z 5 Pro idle problem
Have a 1999 Arctic Cat Z 5 Pro . Cleaned carburetors, put fresh gas. Changed plugs. The sled runs great when at half and full throttle, but as soon as you go to idle, the engine dies. Occasionally will backfire under the clutch side. Any ideas what could be wrong?
Old Dec 23, 2005 | 10:03 PM
fastback39's Avatar
P.S. Have tried tweaking the idle adjustment screws on the carburetors without success. Also, it doesn’t appear to be the throttle cable adjustment screw on the top of the carbs (even though that’s only for adjusting the leveling of the slides) Does it sound like a problem with the ignition (the CDI box or coil)????
Old Dec 24, 2005 | 12:25 AM
Bear4570's Avatar
I would think you need to find a sled form for your answers. I will say this, synchronize the carbs!
Old Dec 24, 2005 | 01:38 PM
Slimegreencat's Avatar
Try your question at http://www.arcticchat.com/ Its an all Arctic cat forum for sleds and quads .
Old Dec 25, 2005 | 02:27 AM
weez440's Avatar
i would say your choke isn't set correctlly cause if your choke is on it will die at idle, but go to arctichat very helpful place to go.
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
