help needed
Old Dec 24, 2005 | 03:23 PM
Bone1208's Avatar
Default help needed
I am changing front sprocket. I can not get my chain to losen. I losened the four bolts on the rear axle housing, put srewdriver in the hole in the sproket, tried to move quad backwards but will not losen chain. I keep breaking or bending the srewdrivers. I tried everything that would fit into that hole but no luck. Any tricks or suggestions woul be greatly appreciated.
Old Dec 24, 2005 | 03:27 PM
rfwlll's Avatar
Default help needed
Sounds like the carrier is froze up. Try alot of penetrating oil and working it. You could also try riding it a bit with the bolts loose, but watch what your doin.
Old Dec 24, 2005 | 04:09 PM
Bone1208's Avatar
Default help needed
Thanks, got it done
Old Dec 24, 2005 | 09:30 PM
2BIG2BFAST's Avatar
Default help needed
Just a quick thought, put the screw driver in and see if it will move forward. sometimes you have to rock them back and forth
Old Dec 24, 2005 | 09:31 PM
2BIG2BFAST's Avatar
Default help needed
Oops i was a little late on that one[img]i/expressions/face-icon-small-blush.gif[/img]
Old Dec 24, 2005 | 11:07 PM
Bone1208's Avatar
Default help needed
2 Big mine actually loosened when i moved it forward instead of backwards. I read when i did a search that you had to move it backwards to loosen. Oh well its done now, but thanks for the reply.
Old Dec 25, 2005 | 02:02 AM
2BIG2BFAST's Avatar
Default help needed
sometimes when it gets stuck like thatand wont move a certain direction you can usualy rock it backwards and forwards and it will brake it loose. One time mine would not move backwards so i rocked it forward and it freed it up.
Old Dec 25, 2005 | 11:51 AM
Scatterbrain's Avatar
Default help needed
Once you get it moving pull the carrier and lube the outside of the carrier with some anti-seize. problem solved.
Sjrpp
Jul 5, 2015 09:04 PM
traumajunkie
Jul 5, 2015 03:03 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
