1985 Honda 110 brakes
Rust. Pull the pedal off and clean the surface on which it pivots. If you have to press the pedal way down to get any brakes it would be a good idea to tun the adjuster in (on the arm on the brake drum). If, however, the adjuster is already in so far that the return spring, that pushes directly on the arm, is mostly compressed you will need new shoes. Oh, be sure to grease (we use waterproof wheel bearing grease) all pivots.
Hope that helps.
Jason
Hope that helps.
Jason
CRamshaw777
Jul 18, 2015 05:46 PM
