Worn out front wheel bearings on Grizzly
Old Dec 30, 2005 | 03:41 PM
zappa24's Avatar
Default Worn out front wheel bearings on Grizzly
Looking for some advice or a good web site on changing the front wheel bearings on my Grizzly. The book I have calls for a puller for the upper ball joint and the tie rod. Only 900 miles and both sides are shot. Does anyone else think thats kinda soon. I do ride alot of rocks.
Old Dec 30, 2005 | 06:51 PM
OGGYDOGGY's Avatar
I just changed mine this past Sept. and 1 on the left rear, it really depends on the amount of mud riding you do. They are fairly easy to change .To get the balljoints and tie rods out just tap on the Bearing hub where the shank goes through , careful not to hit the threads. Mine popped right out . Do you u8se a pressure washer to clean the quad ? I usually dont but im sure it doesnt help the bearings.
Old Dec 31, 2005 | 01:03 PM
zappa24's Avatar
I used a pressure washer a few times but then learned it was not a good idea so now I don't. I'll be working on it after New Years and I will let you know how I make out.
Old Jan 3, 2006 | 02:41 PM
zappa24's Avatar
The problem I am having now is that the bearings fell apart when I took out the axle. I have not been able to get the outside races out of the hubs. Anyone have a trick for this?
Old Jan 3, 2006 | 03:56 PM
hondabuster's Avatar
If you flip the hub over, there should be enough of a lip on the race, sticking out, that you can drive it out.
yambam13
Jul 4, 2015 01:49 PM
Mphillips
Jul 2, 2015 07:20 PM
traumajunkie
Jun 30, 2015 04:28 AM
Rooky
10
Jun 23, 2015 09:35 PM
volsgo30
Jun 4, 2015 06:07 PM
