flashing reverse light
Old Jan 4, 2006 | 04:21 PM
penso's Avatar
Default flashing reverse light
hi, i'm new to forums so be kind!
i have a 2003 raptor with a few mods and very happy with it.one strange thing i have noticed is when it has been idleing for a while and given some short revs the reverse light starts to flash on and off. anybody know about this?
also have a misfire midrange but am about to clean the carb.
Old Jan 4, 2006 | 06:52 PM
maddog56's Avatar
Flashing light typically means your bike is idleing too high, any sustained high idle over 1500 rpms or so will trigger it.
Old Jan 4, 2006 | 08:12 PM
CTracingraptor's Avatar
does it do it when your riding and cut out and pop and the light comes on?
Old Jan 5, 2006 | 04:22 PM
penso's Avatar
no, it only flashes when it has been idleing for a while and then i give it a few hard revs!
have also been told that it is the rev limiter,but am not sure about this.anybody any views on this?
Old Jan 5, 2006 | 05:01 PM
RaptorRRC's Avatar
Your idle is to high. If you are idling around 2000 rpm for around 1 minute the reverse light will flash. Turn you idle down to 1450 to 1550 rpm.
Old Jan 6, 2006 | 01:34 AM
up on your clutch perch, where you parking brake is...their is a wire coming out of goign behind the nose peice, chase that wire down(behind the left headlight) its a two prong connector and unplug it. also ensure your connection is tight on your reverse light, its located down by your front sprocket its a little black plug goign to the case,
SyTye
Sep 11, 2015 02:45 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
