Fuel petcock
Old Jan 18, 2006 | 06:44 PM
Uptmor250r's Avatar
Default Fuel petcock
This morning on the way out to work I notice gas under the quad. Gas was coming from the exhaust port. When I got come, I pull on the pull rope real easy to see if the cylinder was full of gas. It was so I took out the spark plug & pulled to get the gas out of the cylinder. Turn the fuel off. I put a new plug but it was flooded from all the gas.So, what do i do to get this motor to fire up. Do i need to chamge out the oil in the transmission. I called the yamaha dealer to see what is the price of a shee fuel petcok. But they was closed.
Uptmor250r
Old Jan 18, 2006 | 06:54 PM
newnick's Avatar
If it's a four stroke I'd drain the oil for sure. If its a two stroke I'd pull the plug and stand it up on the front of the quad for a while.
Old Jan 18, 2006 | 06:58 PM
Uptmor250r's Avatar
I'm sorry it is a Lt 80. One more thing. What year of shee petcock to get???
Uptmor250r
Old Jan 18, 2006 | 09:37 PM
newnick's Avatar
Maybe Jack Moore could respond, he'd be the best one to answer any lt80 questions.
Old Jan 19, 2006 | 12:12 PM
LT80's Avatar
LT80 Expert
Any year shee petcock. You just cut the tubes down a lil.
Remove the plug and spin till all the fuel is blown out the plug hole (use a rag over it). Make SURE that the plug cap is nowhere near the fuel or a ground as it'll explode and burn.[img]i/expressions/face-icon-small-shocked.gif[/img]
Let it sit a while to dry out, install the plug, give it full throttle and turn over till it starts.
So you have your petcock in the run position and fuel runs out the hose?
Old Jan 20, 2006 | 03:13 PM
Uptmor250r's Avatar
Thank You for the information.[img]i/expressions/face-icon-small-cool.gif[/img]
Uptmor250r
Old Jan 20, 2006 | 03:53 PM
ThrashAndCrash's Avatar
If the cylinder was full............you need a needle and seat for the carb...NOT the petcock!!!!!
Old Jan 20, 2006 | 09:22 PM
DRDIRT11's Avatar
I had this happen because I left petcock in prime position. I just put a carb kit in the carb and it still did it. I have bought a banshee petcock and just waiting for it.
Joe
Old Jan 22, 2006 | 12:36 PM
LT80's Avatar
LT80 Expert
It's usually one of a cpl things. Like stated, in prime position the hydraulic weight of the fuel simply has more pressure than the needle/seat/float can stop. This is why dirt bikes have to shut their petcock off after riding.
Dirt in the needle/seat can happen also.
I've never seen the needle seat wear out to the extent that it actually was a problem. I'm sure I will find one someday.
ltrmc02
Aug 22, 2021 02:34 PM
fordfaithful21
Dec 7, 2015 05:52 PM
mbriggs
Sep 13, 2015 10:47 AM
PrairieDog126
Sep 12, 2015 06:53 PM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
