Polaris Trail Blazer 250 Modification
Old Jan 20, 2006 | 03:36 AM
zombie's Avatar
Default Trail Blazer 250fication
I've got a stock 2005 polaris Trail Blazer 250 I want better performanmce out of it !!!
I thought about changing out the pipe is that enough? ...Whats involved?
I also heard about a clutch kit .....not sure how complicated it would be and if I do go either way will the stock motor handle it?
Anybody got any recomendations?
I appreciated all input.... Thanks
Old Jan 20, 2006 | 03:59 AM
Tyayo420batavia's Avatar
Default Polaris Trail Blazer 250 Modification
im no expert but this is what i think you can do to it: new pipe, bigger jets, new clutch kit, and a new air filter..other then that i think the next step is to bore the engine...
Old Jan 20, 2006 | 07:48 AM
ftwflh's Avatar
There is a good cure for this .......it is the RcR stage 1 kit from Rick Ritter.It comes with everything you need and is very resonablly priced.Do a search on here and you will find his number.
A pipe alone wont help unless you clutch to your pipe.
Old Jan 22, 2006 | 02:14 PM
zombie's Avatar
THANKS FOR THE INFO
zombie's Avatar
Thanks
Nondem
Feb 22, 2020 12:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
