Scrambler 500 no reverse??
Old Jan 20, 2006 | 11:50 PM
bongload's Avatar
Default Scrambler 500 no reverse??
OK..I just had the transmision rebuilt . And when I first got it back it worked ok. but I could tell it didn't feel the same.{when shifting}..Now it has forward gear, neutral{with no neutral light} and when you put it in reverse the neutral light comes on and the bike just sits there like it's in neutral?? any ideas??? Thanks!!
Old Jan 21, 2006 | 07:48 AM
ftwflh's Avatar
THe snapring that holds the reverse clog in place on the shaft has came loose.Not a big deal but you have to pull the tranny out.
Old Jan 21, 2006 | 05:05 PM
scramblerXrated's Avatar
have you checked out your linkage? make sure that its going all the way into gear?
X
Old Jan 21, 2006 | 05:22 PM
TJCINC's Avatar
im with x first, check to make sure they connected your linkage right, you may need to change what tooth on the spline its sitting on, thenif that doesnt do it then yes when they put the gear clog on they did it wrong ir clip broke.
Old Jan 21, 2006 | 06:16 PM
gunman457's Avatar
Hey bongload,
If your neutral light comes on when your in reverse, then I'm sorry to say that something went wrong in your trans. Don't waste your time with adjustments. Pull your trans and have it fixed. And keep your cool when you pull it and install it. Don't forget to use a good case sealer when you put it back together or you'll be pulling the trans again.
[img]i/expressions/face-icon-small-disgusted.gif[/img]
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
r1pilot83
Sep 27, 2015 07:38 PM
exmotocrosser
Sep 26, 2015 08:18 AM
