04 700 carb prob
My carb came stock with a 155 jet,tried a dynojet kit didnt work. I now have a 162.5 jet in carb(EPI recommends this jet for my clutch kit) HOwever it runs for cr%P ! Bogs at about 5000 rpm in high gear, worse when warm . What is the stock needle setting? mines on groove 3 I have opened the mixture up to 1 1/4 turns ARGGGHHH!
in stock form the fuel mixture screw should be set at 2.5 turns out then adjusted from there.carb update page 1
carb update page 2
hope this helps.
carb update page 2
hope this helps.
Zerowick,thank you, thank you! My 700 is back ! used a 160 jet instead of the 162.5 (EPI up grade)or the 157.5 (like the bulletin uses) but no matter, it runs great! Thanx
did you guys know that the polaris tool for adjusting lean- rich mixture while carb is on quad and engine running costs 178$ .? I didnt buy one. took time but I got it thanks for the input!
GregM
Mar 6, 2018 06:53 AM
