04 700 carb prob
Old Jan 21, 2006 | 03:00 AM
itstillruns's Avatar
Default 04 700 carb prob
My carb came stock with a 155 jet,tried a dynojet kit didnt work. I now have a 162.5 jet in carb(EPI recommends this jet for my clutch kit) HOwever it runs for cr%P ! Bogs at about 5000 rpm in high gear, worse when warm . What is the stock needle setting? mines on groove 3 I have opened the mixture up to 1 1/4 turns ARGGGHHH!
Old Jan 21, 2006 | 10:55 AM
zerowick's Avatar
in stock form the fuel mixture screw should be set at 2.5 turns out then adjusted from there.carb update page 1
carb update page 2
hope this helps.
Old Jan 21, 2006 | 01:27 PM
Thanx for the info, I'm goin in! Hopefully this gets it right.
Old Jan 23, 2006 | 12:58 AM
Zerowick,thank you, thank you! My 700 is back ! used a 160 jet instead of the 162.5 (EPI up grade)or the 157.5 (like the bulletin uses) but no matter, it runs great! Thanx
Old Jan 23, 2006 | 01:11 AM
zerowick's Avatar
that's great! nice to get good results after "goin' in" and going through the hassle!
Old Jan 23, 2006 | 05:17 AM
gunman457's Avatar
I was going to say, you sounded like you were jetted to rich. Im glad to see you got it.
Old Jan 24, 2006 | 01:25 AM
did you guys know that the polaris tool for adjusting lean- rich mixture while carb is on quad and engine running costs 178$ .? I didnt buy one. took time but I got it thanks for the input!
Old Jan 24, 2006 | 01:51 PM
zerowick's Avatar
yup, you can find them a lot cheaper, but still hard to justify if you aren't a professional wrench. borrowed a cheap one from a friend but still fried my hands, man they run hot!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
southbayman
Jul 24, 2015 09:30 AM
Aitch
Jul 21, 2015 09:40 PM
