'05 700 EFI- No electrical power
Old Jan 22, 2006 | 11:24 AM
Billyclub's Avatar
Default '05 700 EFI- No electrical power
As luck would have it my friends new 700 has absolutely no power when he turns on the key to start it. We leave in 3 days for Northern Maine to go ice fishing and because there is next to no snow we planned on using the ATV's. He rode it last week without a problem, he went out yesterday and no juice at all. The speedo pod does'nt light up and the fuel pump does'nt cycle on either. Checked the battery it has plenty of juice, Is there a fuse or something inline with the power lead to interrupt or trip the power from the battery. Maybe a ground issue? Anybody with some feedback would be appreciated
Old Jan 22, 2006 | 01:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would think ifyour sure your battery is fine, there must be loose connection between the starter and beyond or there might be a circuit breaker/fuse that is interupping the power.
Old Jan 22, 2006 | 01:58 PM
floodrunner's Avatar
First of all, if it’s new I’d return it to the dealer and have them figure it out. But yeah I know, that would be easier if you could start it. I don’t know how you “checked the battery” but it sure sounds like yours is dead. Check the battery cable connections and connections at the solenoid and chassis ground. Try jumping it with one of the portable battery packs if you have one. Try wiggling the key around in the ignition switch in case the contacts inside the switch are bad.
Old Jan 22, 2006 | 05:20 PM
Billyclub's Avatar
He said he charged it overnight and and tried to jump it with a regular battery without success. I will talk with him tonight and convey what you folkes suggested. Let you know tomorrow
Old Jan 22, 2006 | 07:47 PM
cementhead1's Avatar
Make sure the kill switch is off.
Old Jan 22, 2006 | 08:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
also do a voltage check on the batt. if u can and see if its putting out at least 12 or more volts at start time
Old Jan 22, 2006 | 11:45 PM
upnort's Avatar
On my 03 700 there was a fusible link coming right off battery, 20 amp. Looked like a wire with a small bulge in it. Went I believe to the rectifier up front. When mine went out all was dead like had no battery.
Old Jan 22, 2006 | 11:58 PM
AuburnGrad's Avatar
You may try taking the headlight pod off and checking the connection behind the switch. Also, check to make sure the connectors going into your headlight/revoverride/killswitch box on your handle bars are secure.
Old Jan 23, 2006 | 05:56 AM
gunman457's Avatar
Try a load test on the battery. I had one with a broken post. It show 12 volts untill I put a load on it and it acted like a loose battery cable. Lead batteries can't take a lot abuse.
Old Oct 31, 2006 | 06:44 PM
rubberknob's Avatar
Did your friend find out what the problem was?? I have the exact same problem with my 05 500HO.
thanks
rubber ****
Ripinandtearin
1) Engine problems..
Dec 11, 2017 08:06 PM
akbrewcrew
Aug 9, 2015 10:54 PM
Derek Allen
Jul 22, 2015 09:25 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
Unzzy66
Jul 11, 2015 10:01 PM
