spyder tracs
Old Nov 7, 2000 | 10:52 PM
Tnye's Avatar
I am putting 25*13.5*10s on my trail blazer but i don't know what size to put on the front stock it's back 22s and front 23s but i don't think i can get the right size fronts does anyone know what size front's i can use thanks...
Old Nov 7, 2000 | 10:59 PM
waynaferd's Avatar
Gees, If you think your Tblazer's underpowered now, wait till you bolt them on!!!!!! But try narrower 25's in front, too.....
Old Nov 7, 2000 | 11:30 PM
WIscrambler's Avatar
Hey TNYE~
I'd say try the 25x8x12 on the front. That would give you similar tires as the 400 explorer and SP500. Ground clearance is obviously a concern for you. But your engine does not have the power to turn tires that large. You would have to change to a larger rear sprocket or smaller front sprocket. Larger tires will also increase the wear on the machine. Unless you absolutely have to have the ground clearance, I would highly recommend getting 22" rear spyders. You could save some money by keeping the front stock tires. The Spyders are heavier than stock tires so 25" tires would be an overkill for your machine. One question...Do you know if 25" tires will even fit on the front without rubbing?
Old Nov 8, 2000 | 07:47 AM
Tnye's Avatar
thanks for the help guys!
beartracker14
May 30, 2001 01:31 PM
sugarhead
Mar 21, 2001 04:52 PM
polarisz71
Mar 13, 2001 10:59 AM
TDBRPH
May 15, 2000 10:52 AM
vmaxer
Apr 27, 2000 08:57 AM
