05 Grizzly wont start, need help
Old Jan 28, 2006 | 04:33 PM
FranktheTank76's Avatar
Default 05 Grizzly wont start, need help
Hello, I have a 2005 Grizz and is not getting any gas. It turns over and runs with starting fluid sprayed into the carb.
Any ideas what's wrong? Fuel filter, frozen line????
P.S. Yes there is gas in the tank.
Thanks
Old Jan 28, 2006 | 11:53 PM
TORK's Avatar
Pull fuel line off at carb and make sure that you have good flow to carb. If so then you have jets plugged up and carb will have to be pulled and cleaned. Could be debris in jet or even water in fuel ( water is denser than gas and will plug off a jet like a fuel shtoff.
P.S. I hope by starting fluid you don't mean ether.
Old Jan 31, 2006 | 06:16 PM
Hey, Thanks for the help Tork. There was gas flowing through the line to the carb, so must be something plugged in the carb. I'm going to tkae the carb of tonight and clean it.
What's the deal with ether?
TLC
Jul 1, 2015 08:29 AM
RPK
Jun 8, 2015 01:05 AM
atvdave
Jun 4, 2015 06:06 PM
1000gade
May 27, 2015 12:37 PM
Undecided350
Jan 15, 2001 03:55 AM
