Grizzly headlight problems
Old Jan 30, 2006 | 10:55 PM
superdman's Avatar
Default Grizzly headlight problems
I have a 2004 grizzly and the left headlight is really dim. They are aftermarket blue bulbs,
not sure which ones. Anybody have a clue? Is it a stator problem or the bulb itself?
THanks!
Old Jan 31, 2006 | 01:43 AM
Kodiak660's Avatar
If its just one bulb I would just replace that bulb.....if it was anything else it would effect all your lights and other things.
Old Jan 31, 2006 | 04:28 PM
tencubed's Avatar
Being retired is a hoot!
You might want to be sure the ground wire to that bulb is good. Often a dim bulb is the result of a corroded ground wire. Less often the hot wire is the problem.
Old Jan 31, 2006 | 07:55 PM
superdman's Avatar
Thanks, I'll check the ground first and replace it if that doesnt work.
Much Appreciated!
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
JoAnnS
Jul 23, 2015 02:18 PM
Captjay
Jul 23, 2015 12:33 PM
tweeder
Jul 5, 2015 01:57 PM
