Need help fast with 05 Grizz
Old Jan 28, 2006 | 05:30 PM
FranktheTank76's Avatar
Default Need help fast with 05 Grizz
Hello, My Grizz is not getting any gas. It turns over and runs for a bit when I spray starting fluid into the carb.
Any Ideas what might be the problem??
Any comments are much aprreciated.
Old Jan 28, 2006 | 07:27 PM
rockroller's Avatar
is the gas line off ? try tuning it around and back 1 or 2 times see if anything helps ? sorry no help
Old Jan 28, 2006 | 07:48 PM
Yep, gas is turned on and is flowing through the line. I disconnected the gasline where it connects to the carb and gas flowed out.
Thanks for the reponse though.
Old Jan 28, 2006 | 10:32 PM
hondabuster's Avatar
Could be a few different things.
How many hours on the motor, and when were the valves last adjusted?
Are you trying to start it with the choke on fully? If you use a steady 1/4 open throttle., while cranking..will it start and run then?
When using the starting fluid...and when it catches and runs...what happens if you hold the throttle at 1/4 open? Does it die, or will it run?
Because you have the air lid off and the filter out (to spray the starter fluid), that will make it very lean, and it will be hard to start. Are you doing this in a cold garage, or in a heated area?
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
1000gade
Sep 19, 2015 10:28 AM
toonces
Sep 5, 2015 01:14 PM
