New clutch upgrade or rebuild stock clutch.....SP 500
Old Jan 29, 2006 | 12:41 AM
hc's Avatar
hc
Default New clutch upgrade or rebuild stock clutch.....SP 500
Need some advice from those that have rebuilt or replaced their clutch systems.
I have a 99 SP 500 (bought new) 1500 + miles but is in good shape. All stock except the tires. They are Goodyear Mud runners. (factory size 25" just a lot heavier than stock)
My questions are about my Primary and Secondary clutch. It just doesn't hook up like it use to.
Should i replace the primary with a Hypershift and the secondary with a Team Roller from Hot Seat. If so what would be the matching set combination.Or rebuild my stock primary and replace the secondary with a Roller.
Or just rebuild both stock primary and secondary?
I mostly just trail ride, with some rock trails and some mud ridding. And what tools would i absolutely have to have to do this clutch work?
Need some hookup......untill i can upgrade to 800SP.
Thanks for your replies.
Old Jan 29, 2006 | 01:52 AM
Polaris500HO4x4's Avatar
Have you tried replacing the belt?
Old Jan 29, 2006 | 01:56 AM
hc's Avatar
hc
Yes it has the second belt on it that was change not too long ago. I am sure my clutch needs somthing done to it, but was also thinking about upgrading it anyway.
Old Jan 29, 2006 | 02:04 AM
I guess the new sportsman 800 clutch is supposed to be pretty nice! i dont know for sure if it will fit on your model
Maybe your buttons are worn out in your clutch
Old Jan 29, 2006 | 02:12 AM
hc's Avatar
hc
When i get a chance from working so much i plan on looking into it and see what it needs.
I am thinking about a roller seconary clutch anyway.
Old Jan 29, 2006 | 10:02 AM
ftwflh's Avatar
I would go with the TEAM secondary and have the primary rebuilt with either a Heelclicker or the Hypershift kit.Heelclicker is more for the lowend pulling.But if you catch Speedwerx on here he may be able to get you a Hypershift kit setup the way you need it.
Jmuddin284
Jan 19, 2026 07:16 AM
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
ghost civic
Jan 15, 2020 07:43 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
