12 tooth front?
Old Jan 30, 2006 | 04:00 PM
LHUraptor350's Avatar
Default 12 tooth front?
I was just wondering if my 350 raptor would climb hills a lot better if i put a 12 tooth front sprocket on???? Also i wanna make it climb hills a little better, but i dont want to go to radical with big bores and i already have a lot of mods.....i have no idea what to do?
Old Jan 30, 2006 | 04:11 PM
bombaman's Avatar
that will give a little more power.
Old Jan 30, 2006 | 08:07 PM
recon99's Avatar
It may help with hill climbs if it seems like you can't find the right gear for them. Personally I think a 12t is a little too low with stock sized tires. Even with taller tires I find myself shifting like crazy when I crack the throttle wide open.
Old Jan 31, 2006 | 12:13 PM
Kudzu's Avatar
I put a 12 on my Banshee because I ride in the woods and with the stock gearing I never got higher than 3rd gear before I had to back off because of was going so fast. So I figured gearing down would give me more low speed punch and allow me to actually use those top 3 remaining gears. But I will admit this is on a Banshee which has rocketship top end and a powerband that will peel your face off, but nearly nothing on the bottom, so lower gearing lets that power kick in earlier. Your Raptor has a more even powerband so it might not be such an issue. Changing a front sprocket is no big deal just to give it a try, and they aren't real expensive, as long as you have enough chain adjustment to not need to take links out of your chain.
Old Jan 31, 2006 | 04:35 PM
YamahaRider8998's Avatar
Would a 14 tooth front be good for a warrior, i want some speed because i ca open it up in alot of places but i still want me low end, and would a 15 tooth be way to high for that.
steve
Old Jan 31, 2006 | 05:11 PM
recon99's Avatar
What size rear tires do you have? Taller rear tires have the same effect as a larger front sprocket. So far the best gearing setup I tried on my Warrior with 22" tires was 14/40. I could get up to about 66 mph on the 'turnpike' at Tower City with a dying clutch and before I had my edelbrock installed. (I'm hoping for around 72 now) Look at my picture gallery to see what the 'turnpike' is
Assuming you also have 22" rear tires, i'd say a 14t front sproket is the highest you would be able to go while keeping the motor in the powerband in 6th gear.
You don't have to worry too much about losing low end power from high gearing with the warrior in stock form. With the stock cam the Warrior pulls like a tractor.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
