Removing the PB on my Warrior
Old Feb 3, 2006 | 06:00 AM
89warrior's Avatar
Default Removing the PB on my Warrior
I just put a ez pull clutch perch on my warrior. What do I do with the wire with wire? should I remove it? Or is there something special I need to do?
Old Feb 3, 2006 | 09:07 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
OOO PARKING BRAKE!!! gotcha... the 2 wires you can disconnet from the lever( have to take hood off and take then off there too) the cable should be easy to take off... be sure to get a PC Block off plate for the rear otherwise dirt will get in your caliper and screw it up.
Old Feb 3, 2006 | 02:25 PM
recon99's Avatar
There should be 2 sensors/switches on the stock perch. I don't know if the ez pull levers have a space to put the clutch switch, but if it doesn't you can unplug it from the harness, and plug the harness back into itself to bypass the switch. You can just unplug the PB switch like speedy said.
Old Feb 4, 2006 | 02:38 AM
89warrior's Avatar
I only found one sensor. The one hooked into the perch. So after i follow the old sensor wires to the harness i just unhook it? Then hook the wires on the harness together?
Old Feb 4, 2006 | 11:14 AM
Speedy2222's Avatar
yep..
Old Feb 4, 2006 | 12:32 PM
recon99's Avatar
if the sensor has a single plastic connector just unplug it and leave it alone. If it has 2 seperate spade connectors plug one into the other.
Is your clutch perch the original clutch perch? Mine had 2 sensors on it. They looked exactly the same, but one was for pb and one was for the clutch. (maybe 89's had a different setup, but i'm not aware of it)
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
