NEED INFO on 1988 FourTrax TRX350D
Old Feb 5, 2006 | 01:09 AM
ricweber's Avatar
Default NEED INFO on 1988 FourTrax TRX350D
I just acquired a very sad '88 FourTrax 350 4x4. Until I can purchase a service manual, I have a few questions.
[1] Is it always in four-wheel drive, or is there a provision for disconnecting the front drive?
[2] Are all four tires supposed to be the same size?
[3] Does it have a reverse gear?
Thanks in advance for any advice. You can email me directly at [ weber@directcon.net ]
Ric
Old Feb 5, 2006 | 01:33 AM
1988TRX250R's Avatar
1)Yes, it is always in 4wd. 2)All 4 tires are the same size -- 24x9x11. 3)Yes there is reverse. I'm pretty sure those have a reverse lite on the dash along w/ a neutral lite. Also look near the left hand brake, there should be a red button w/ an R on it. Push the button, pull in the brake, and downshift from neutral, you should be in reverse.
Old Feb 5, 2006 | 04:52 AM
ricweber's Avatar
Thanks, That helps.
The dash is missing and most of the wiring has been pulled out so I am in a real steep learning curve on this quad.
Am I correct in thinking that there is a solenoid in the transmission that pulls a reversing gear into the first gear position?
Ric
Valder
Nov 28, 2020 07:38 AM
buddieboy
Dec 9, 2016 05:50 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
