WARRIOR TRUOUBLE
Old Feb 5, 2006 | 11:35 PM
10000's Avatar
Default WARRIOR TRUOUBLE
IT WILL START AND RUN FOR ABOUT A MINUTE THEN START POPING AND DIE. WHAT COULD THE PROBLEM BE?
Old Feb 5, 2006 | 11:40 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
WHY DO YOU TYPE IN ALL CAPS!?
also, it may be dirt in the carb, your choke may be on, your jetting may be off, it may be running out of gas
Old Feb 5, 2006 | 11:43 PM
hondabuster's Avatar
The popping is usally a sure sign of lean. Jets could be plugged, fuel filter plugged, running out of gas...or even old stale gas.
Old Feb 6, 2006 | 12:03 AM
Speedy2222's Avatar
if i were you, flush the gas tank and put FRESH 87/89 octane gas into it, get a fuel filter( replace the one you got if u have one), make sure gas is actually getting to the carb. if you need furthur help you may want to take it to the stealership. and a 383 big bore is a very OFF bore.. that must be like .015 over?
Old Feb 6, 2006 | 10:49 AM
recon99's Avatar
Once the gas cap breather vent got plugged up on the Prairie 400 I had, and it did the same thing. Try loosening the gas cap a little bit so some air can get in. If fresh air can't get into the tank, then the gas can't get back out and it'll act like it's jetted too lean.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
