do i have to remove the plastic gear?
Old Feb 7, 2006 | 09:49 PM
warriorryder's Avatar
Default do i have to remove the plastic gear?
if i just take the oil injection pump off of my blaster and leave the gear in it would it be ok? or should i just pay $30 for the block off kit? I'm getting an aftermarket carb so i have to remove it.
Old Feb 7, 2006 | 10:24 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
sometimes it's called a BLOCK OFF kit for a reason.. think.. hhmm pay the $30 or be cheap and not run it.
Old Feb 7, 2006 | 10:44 PM
alright... i guess i'll buy one...probably time to change the tranny oil anyway lol
oh one more thing...what kind of oil should i buy for the tranny...i don't have the manual so i'm not sure
Old Feb 7, 2006 | 11:35 PM
MDS2106's Avatar
Remove the clutch side cover,then remove the pin and the plastic drive gear off of the oil pump. Reinstall the cover, with the gear removed the oil pump will function as the block off plate.Plug the hole on the carb,remove the rest of the oil inj. crap and cut the oil lines flush with the side cover.After refilling the trans. with oil you are ready for premix.Save that 30.00 for something else like a adj. stator plate.
Old Feb 7, 2006 | 11:39 PM
really? thanks a lot...i won't have to plug the hole on the carb because i'm buying a new one
ghost civic
Jul 15, 2015 10:48 PM
toonces
Jul 11, 2015 12:01 PM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
