primary spider buttons
Old Feb 9, 2006 | 04:07 PM
Whitedog's Avatar
Default primary spider buttons
has anyone on here had any trouble with the buttons that go inside the spider? I took my clutch apart the other nite and the buttons are comming apart. The teflon face seems to be twisting apart from the rubber backing. These are fairly new, from EPI and dont have that much time on them. Could this be because the surface that they ride on is worn bad?
Just wondering if anyone makes a severe duty button or not.
Thanks
Old Feb 9, 2006 | 04:43 PM
atvdragracer's Avatar
whitedog......the surface thay ride on should be smooth.
Old Feb 9, 2006 | 08:37 PM
ftwflh's Avatar
THe slides need to be smooth or it will wear out buttons fast.If you have wear it would be time for a new clutch you can rebuild (swap parts) because they are balanced as a unit.
Old Feb 9, 2006 | 11:00 PM
Whitedog's Avatar
Yea, this clutch is pretty worn. I took some emery cloth to the surface of the tower where the button rides, and I also called Darryll at hpd. He sold me some snomobile buttons. He said they are little stronger and dont have the rubber backing. (this is where they are coming apart)
Old Feb 10, 2006 | 02:32 AM
duneaholic's Avatar
Hey Brad. Did you mean to say that you can't rebuild them? I've tried and it don't work. [img]i/expressions/face-icon-small-blush.gif[/img]
Old Feb 10, 2006 | 07:45 AM
ftwflh's Avatar
THat right you cant rebuild them.But you can do like Whitedog did and get a little longer out of them.
Old Feb 10, 2006 | 09:47 AM
duneaholic's Avatar
Just wanted to make sure to clarify if someone thought you said you could. Cause I tried it and shredded two belts in real short order.
Lucas Bohanan
Sep 29, 2015 01:16 AM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
