Need Help With My 79 odyssey
Old Feb 11, 2006 | 08:46 PM
Bertabugnu's Avatar
Default Need Help With My 79 odyssey
It has a 250 cc motor, points.
It will run fine for about 10 minutes till its warmed up then it starts to bog down lossing power then dies it wont restart for about 15 minutes or untill its cooled. the spark is getting weak. after a few of these cycles it will foul a plug. any ideas on why this is happening and what I can do to repair it? Ive already replaced the ignition coil. any help would be appreciated.
Old Aug 4, 2006 | 12:56 PM
canner178's Avatar
have you tried cleaning the the points
Old Aug 4, 2006 | 06:35 PM
Bertabugnu's Avatar
Yes We Have. Husband thinks it might be the advance mechanism. Still stumped though!
Old Aug 5, 2006 | 07:24 AM
HondaMechanic's Avatar
none
Old Aug 5, 2006 | 07:04 PM
knauf's Avatar
Could be a bad ground I have heard of that happening on an odyssey. Have you tryed Hosers odyssey forums. If not give Randy a call at odyssey salavge he is a good guy and will do anything he can to help you out.
Old Aug 7, 2006 | 04:49 PM
Corey64's Avatar
I had the same problem on my odyssey turned out the fuel filter was clogged with rust from the fuel tank.
ThrashAndCrash
ATC 3-Wheelers
Apr 10, 2004 05:21 PM
odysseyjunk
Feb 6, 2004 07:18 PM
DSJOBBER
Sep 29, 2003 08:57 PM
spdkills
May 5, 2003 07:33 PM
