Eiger Carb Help!
Old Feb 13, 2006 | 09:22 AM
Rags1317's Avatar
Default Eiger Carb Help!
I Know I have read about this problem carb for awhile now and I have done everything I read about too try to fix. It works for awhile & then Back too the same trouble!
Some times it will Idle & some times won't. I have adjusted Idle mixture, cleaned air filter, changed plug, took carb apart & removed every part & cleaned, replaced fuel filter{ inline }, I put it together it runs excelent for a couple hours then back to the same problem. I am constantly adjusting the idle to keep it running. Every once in awhile it will act perfect then all of a sudden Idle drops & stalls & won't start unless I push on accel,
I am going to take it apart AGAIN! Please any Ideas what too check next.
Old Feb 13, 2006 | 10:12 AM
calsatman's Avatar
my nephews eiger is having almost the same problem, just not quite as bad as yours. have adjusted the idle several times and it may go 2 weels before it acts up again, but eventually it does and well have to turn the idle up to get it to stay running. also i noticed that if the bike is idling and you stand up on the pegs and shake the bike just a little bit it will die. it seems like every time we get the bike in a off camber spot(going up or down steep banks) if it leans just a little to one side it will die every time. wish i could help you but im drawing a blank on this problem so far.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
baysport
Jul 23, 2015 11:37 AM
Aitch
Jul 21, 2015 09:40 PM
