Exhaust seal leaking where pipe meets engine
Old Feb 14, 2006 | 04:28 PM
BANSHEEBRUCE's Avatar
Default Exhaust seal leaking where pipe meets engine
My 400 Scrambler leaks between the pipe (CPI) and the exhaust manifold, turns the whole front of the engine black, I'm picky about that stuff! I tried High temp. Slicone gasket sealer, didnt work. Also, bought a new exhaust ring at the stealership ($20), looked the same as the old one, took it back. Anyone know what else works, how about the springs can you get stronger ones?
Old Feb 14, 2006 | 04:44 PM
badazz400's Avatar
hey mine does that too!!! or at least it did until i learned her out 60 to 1. but it still leaks. i need to do something about that. glad you mentioned it.i beleve you kan find some tighter exhaust springs at your local hardwear store or at hpd.com. tell ya something else, i think where the header pipe meets the actual straight pipe is a **** pour setup. 4 1 it doesnt fit very snug. 4 2 u got this pretty chrome pipe with a big ole brass lookn spring stickn out. they shouldve made the spring mount behind the pipe so no 1 could c the spring. If they realy wanted to be innovative they couldve made 2 spring mounts 1 on each side for extra supports
dont mean to critize the pipe. i own 1 so i guess i have the right too.
ross
Old Feb 14, 2006 | 04:52 PM
badazz400's Avatar
come to think of it about two months ago i fixed that problem!!!
the springs i had went from the exhaust to the cylinder with little effort. you could dam near hook the spring with your hands.
i took the springs and cut the hooks and bent new hooks. now they go on real tight.
i havent rode in bout 2 months so i kant tell u how they worked. but i believe i fixed the problem
hope this helps
ross
Old Feb 14, 2006 | 05:18 PM
conig's Avatar
I have the same problem, I havn't been able to find springs short enough to stop the leaking.
I was going to try high temp silicone but now I think ill try the spring trick.
Old Feb 14, 2006 | 05:28 PM
duneaholic's Avatar
My HPD trail pipe did that real bad. My CPI isn't quite as bad. It seems to gumm up after a while and doesn't leak too bad after that. Just spray some degreaser on the blow by and it usually will wash right off.
Old Feb 14, 2006 | 06:17 PM
Hey thats a good idea about the springs, I'm going to try that. I'm running Amsoil 50:1, and it still makes a mess. The guy who owned it before me was running Castor 927 and that stuff is very hard to get off. lots of elbow grease!
Old Feb 14, 2006 | 06:20 PM
conig's Avatar
ditto I think on mine oil may be inpregnated into the aluminuim just below the cylinder. lol
hugemoth
Jul 20, 2020 03:28 AM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
bikedad3
Jul 2, 2015 02:15 AM
