loose front end on sportsmen
Old Feb 16, 2006 | 08:27 PM
lawnboy2121's Avatar
Default loose front end on sportsmen
I seen that the lower ball joints in my Sp were loose. The machine has 600 miles and is a 05. I took the cotter pin out and could turn the nut with my finger. The left one had a lot of play until I tightened it up. Any one else have this problem? And also the front struts seem to have a little play on top is this normal. The nut is tightened up all the way.
Old Feb 17, 2006 | 01:18 AM
Polaris500HO4x4's Avatar
doesnt seem normal to me... i do know that the sportsman lineup does have a negative camber where the bottms of the tires stand out farther then the front but there shouldnt be any free play
Old Feb 17, 2006 | 04:57 AM
jimmypsp700's Avatar
check your tie rod ends for slop.
Old Feb 17, 2006 | 04:57 PM
the play is coming from the top of the strut. Where the rod goes thruogh the frame. It seems like the ruber is worn or the shoulder of the rod is to long so you cannot tighten yhe nut. The washer bottoms out on the shoulder of the rod. If you grab the A arm you can move it up and bown about 1/8 "
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
carolinabomb
Jul 26, 2015 08:40 AM
TLC
Jul 25, 2015 02:24 AM
tporath
Jul 11, 2015 12:31 PM
